This is has been a pretty bizarre week. First off, about a week ago i was driving my 88 325iC, running perfectly, and it completely shut off. no sputtering, just off. I pulled over, and it started right up. This started to happen every time I would drive it, then twice every time I drove it, and taking longer and longer to start after it died. Finally it died and never restarted. Changed the crank position sensor, had vibrant spark, new fuel filter, pump buzzed upon cranking. Still nothing. Pulled a plug, and no wetness or gas smell. Finally I pulled the intake off and sprayed starter fluid in the throttle body. Started and ran, idled, revved up. Next day (with intake box still disconnected) started and ran. Turned it off, connected the airbox and plugged in the MAF sensor, and would not start. Took it back off, sprayed fluid in, still didn't start. WTF???
My neighbor and I think it is the fuel pump going bad, and it is overheating and working sporatically, and even with the buzzing, it may not be pushing enough pressure to open the injectors.
Any help would be appreciated! My crew is stumped!
-Brian
-Brian
