Long start, stumble, then ok
  • delatlanta1281
    Dart Master
    • Mar 2006
    • 10317
    Lately my car has had a weird starting issue. It doesn't happen all the time, but more than not.
    I turn the key and it turn over for @ 7 seconds than stumbles to idle. It then runs fine, smells a little rich, but fine. Any Ideas?
    THX
    Rich
    Yours truly,
    Rich
    you kids get off my lawn.....
  • mattdk318i
    • Jun 2006
    • 3953
    check your fuel pressure regulator
    • delatlanta1281
      Dart Master
      • Mar 2006
      • 10317
      I am running a porsche adjustable. I wonder if it is too high perhaps?
      Yours truly,
      Rich
      • mattdk318i
        • Jun 2006
        • 3953
        hmm, good question. Could have something to do with the fuel filter. Unless thats new as well.
        • delatlanta1281
          Dart Master
          • Mar 2006
          • 10317
          It isn't, I had an intake manifold gasket rip earlier this month and cause problems, I just replaced all of them, and have run into this problem. It is probably something I did wrong upon reinstallation of the removed parts... I am going to go over all my injector connections when it cools down later. I may turn my fpr down a tad to see if that's the problem. If it persists, I will probably change the pump/ filter (I doubt those are problems b/c it runs fine, but they're old).
          Yours truly,
          Rich
          • FlyingPrick
            • Oct 2007
            • 67
            does it happen all the time or just on a cold start? i have a slow start only when cold which i am starting to believe is a problem with the (and i hope this is right) drainback valve on the fuel pump where it's letting fuel drain back from the rail into the tank and when i cold start it, the rail has to refill, etc. i have replaced everything but the fuel pump and the injectors, as far as the fuel delivery is concerned.
            I'd rather have Sarah Palin 1 hearbeat away from the Presidency than Nancy Pelosi 2 heartbeats away.
            • delatlanta1281
              Dart Master
              • Mar 2006
              • 10317
              Pretty much all the time.
              Yours truly,
              Rich
              • delatlanta1281
                Dart Master
                • Mar 2006
                • 10317
                Injector 6 leaking a bit, I just found it so that may be the problem. It starts when warm, but after 15 minutes there is a problem.
                Yours truly,
                Rich
