I vs. E main relay wiring
  • JAM
    • Feb 2007
    • 524
    same? different? if the latter, what is the difference?
    thanks!
    Originally posted by Mr Watsonsilver
    driving boards?
  • Aptyp
    • 6584
    Same for fuel pump and main. Oxygen sensor, i am not sure about.
    • JAM
      • Feb 2007
      • 524
      wrd cool thanks man. im running a wb so no need for that. im mainly worried about the main wiring, a po fucked this shit bad and my ecu is cutting out im guessing from a bad connection. hopefully this is the problem :fingerscrossed:
      driving boards?
      • rs4pro3
        • 5808
        Wrong the main relay wiring is different, but the function is ruffly the same, on the I cars the ecu grounds the main relay to kick it on, and it always has power, where as on an eta car the main relay is always grounded, and the power to the relay is switched to kick it on.
        85 325e 2.7 ITB'd stroker
