Oilpan replacement
  • jamiholzbach
    • 311
    Oilpan replacement
    i'm trying to figure out a way to replace my oilpan without dropping the front suspension or removing the oil pump. I thought it may be possible to undo the passenger side motor mount, loosen the driver's side, and place a block of wood on a floor jack under the A/C compressor. Then jack the motor to one side for clearance. Has anybody tried this before? any tips or tricks?
  • Aptyp
    • 6584
    lift the engine
    disconnect motor mounts, that allows you to lift engine about 1-2 inches, gives you planty of room to do the job.
    • homegrone30
      • Jun 2007
      • 1449
      Ive never succesfully been able to put a gasket on but pookie has always held for me.
      • bataangpinoy
        • Jul 2008
        • 1636
        write up by mr anderson.
        My feedback:
        http://www.r3vlimited.com/board/showthread.php?t=186328
        http://e30tech.com/forum/showthread.php?t=74911
        Instagram:
        @gears_n_glory
        @functionmotorsports
