spongey brakes?
  • 87-325ic
    • Apr 2006
    • 1198
    spongey brakes?
    hey everyone, now that my car runs, i have a quick question..
    the car has been sitting around for a few months. not being driven.
    before i left it, the brakes felt fine. push once and you'd have brakes, but let up and push again and they felt "firmer". I guess this is a small vacuum leak???
    second, now that im back, my brakes feel like they dont work 1/4 of what they used to.. the pedal neds to go to the ground almost before it feels firm and stops the car..
    is this some air that worked into the lines? ive checked the fluid level and its fine.. what should i look at next?
    thanks.
  • Hallen
    • 1008
    Bleed the brakes. It's always the first step. Then if that works temporarily, you probably have a leak somewhere. If it doesn't work, then it is most likely the master cylider
    1987 E30 325is
    1999 E46 323i
    RIP 1994 E32 740iL
    oo=[][]=oo
    • submwar
      • 216
      +1 , you've got some air in the lines. good time for a brake fluid change
