Never had this problem before. The 7.5 amp fuse that controls the AC fan and all the gauges (except the speedo) keeps blowing. Usually when at idle with the AC on. Is this a sign that the resistor or the blower motor is failing? Anything else?
Blowing AC and gauge fuse
mine just started doin the same thing. Im pulling up the diagrams tomorrow to have a looksee into the circuit. -
I had a similar problem a while back. There's an electrical line that runs from the shifter forward. The clip that holds it up broke and the line fell down and was resting on the driveshaft. A little bit of time and it started shorting out on the driveshaft (occasionally). Same fuse. Check it and see.Comment
