I want to know how hard it is to retrofit a m20 cruise control to a m42. It should be a pretty direct swap correct. I know theres something wrong with the actuator but can i manufactor a braket or something to make it work. thank you.
Cruise control (M20 to M42)
The hardest problem I encountered was making the cable work on the throttle body. I ended up ordering a new gas pedal cable and using various parts from it to make it work.what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
yes it can be done. Not all that hard. I did it on mine..
I have a write up over at m42club, here is a link
www.classicdaily.net
1970 m42 swapped 2002
1985 LS1/T56 Swapped e28 (557e)
www.blunttech.com - For all your parts needs
Follow me on Instagram for constant build updates @classicdaily
https://www.facebook.com/ClassicDailyLLC
