e/es vs i/is cluster
  • rodrigo
    • Aug 2007
    • 923
    I need another cluster gfor my 'i', and have a great offer on an 'es cluster.
    what are the diferences...they are both motormeter.
    thanks in advance
    R
  • SpartanTiger81
    • Sep 2007
    • 555
    Correct me if I'm wrong, but all e's redline at 5, while I's redline at 7. I think that may be the only difference?
    • AndrewBird
      The Mad Scientist
      • 11898
      Yes, the tach is different, but the rest should be the same.
      A little tip. The way to tell if one cluster is compatible with another is to look at the service indicator lights. One type has 3 red lights, the other has 1 red light. As long as two clusters have the same number of lights, they can swap parts. It doesn't matter if they are Motometer or VDO.
      I am pretty sure either cluster will work in any car, meaning you can swap a 3 light cluster into a 1 light car or visa versa.
      • rodrigo
        • Aug 2007
        • 923
        so the 'es' cluster will show a redline from 5000 to 7600 and the 'is' cluster will show redline form 7000 to 7600?
        (i dont have my car at my place at the moment so I cant go and look...mine is an 'is')
        • SamE30e
          • Sep 2007
          • 4319
          Nope, the E tach only goes to 5k it has a 4500rpm redline. You can swap the faceplates though. Just change the coding plug.
          1985 325e 2.8 Turbo VEMS
          • lordofthewaters
            • Oct 2005
            • 714
            If the 7k tach works, just swap it into the the es cluster, and be sure to use the is coding plug and you'll be set.
            Sarcasm is a body's natural defense against stupid.
            When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
            "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
            Old age and treachery will always overcome youth and skill.
