Why is my car leaning to one side...
  • Jand3rson
    • 37587
    I noticed about a week or so ago that my car has a definite lean toward the driver side, you can see it from the back and from the front, and my fender gap is slightly larger on the passenger side, at both wheels. I haven't made any suspension changes or anything, and the only weight differences are that I've removed the AC compressor, and I don't have a passenger seat currently. But I removed the compressor over a month ago, and I've just recently noticed the lean. The air in my front driver side tire is a bit low, but I don't think that would causing the whole car to lean. Any ideas?
  • Rob
    • 8166
    Is it constant? Occasionally a car parked on an uneven surface can get a slight lean that will go away with driving.
    Other than that, could one or more of your spring pads (assuming you're running any) could have given up or jumped ship.
    If it really bothers you and nothing easy fixes it, you could try putting the springs from the drivers side on the passenger side. If its mainly you in the car, I could see a drivers side spring set wearing more quickly (extra 200lbs or whatever you weigh on that side)
    BEERTECH
    • Jand3rson
      • 37587
      It's noticeable on any surface, and most in my garage, which is flat and level. I'll check the spring pads tomorrow, I hadn't thought of that. Also, I'm pretty much always the only one in my car, so I could see that as a possiblity, also. Maybe I'll swap them out.
      I just took some measurements, they are as follows, from flat ground in my garage:
      Passenger side:
      Front wheel well - 24 3/8"
      Rear wheel well - 24 1/4"
      Side molding - 18 1/8"
      Rear bumper - 20"
      Splitter - 4 1/2"
      Driver side:
      Front wheel well - 23 3/4"
      Rear wheel well - 23 3/4"
      Side molding - 17 3/4"
      Rear bumper - 19 1/4"
      Splitter - 3 3/4"
      Looks like it's between 1/2" and 3/4" difference all around.
      • Hodge
        • Jun 2008
        • 424
        Weird...
        I find this funny because my E36 tends to lean on the passenger side slightly... It might just be my eye though.
        I would definitely check the pads, run for a few days after checking and if that doesn't work, just swap the springs.
        E30- 1989 325is
        • Danny
          • 14216
          E36s lean to the side because when the driver gets in it evens out the weight balance.
          BMW designed them that way, or so I've read.
          • TDE30
            • 7042
            Have you checked the tire pressures?
            - Trey
            E90 325i/6 (ZSP, ZPP, ZCW)
            E36 325i sedan
            E30 325i sedan
            Volvo 945T
            • Quadrajet
              • Jul 2008
              • 1278
              What are you running for a sound system? Is the weight distributed? Just a thought.
              • Jand3rson
                • 37587
                No system at all. All stock.
                • speedhop
                  • 1509
                  Stop driving fat people...
                  Has the car ever been in an accident? Maybe the body got tweaked and your mounting points are higher on one side versus the other. That or tire pressure...
                  www.ryanwhopkins.com
                  • Jand3rson
                    • 37587
                    It was not doing it a few weeks ago. I think my tire pressures on the driver side might both be low, I'll check them out.
                    • Jand3rson
                      • 37587
                      It must have been something related to tire pressure, because I just had my car in to get a slow leak in my left front tire fixed, and now that I have it back, the lean is gone. But I could have sworn I put air in the tires before, and it was still leaning. Who knows.
                      • golde30
                        • 11464
                        mine leans, its b/c the car is 20yrs old and had mostly only a driver in it the whole time. shit, i know my lean is b.c of my 240lbs of manlyness.
                        IG: @Baye30
                        • Jand3rson
                          • 37587
                          We weigh the same. lawl.
                          The front is still leaning down on the driver side slightly, but the rear appears to be fine.
                          • emi325i
                            • Oct 2006
                            • 356
                            Did you set your parking brake? put the lever down and see if it evens out. if it only grabs one wheel it'll do that.
                            • audiquattrot
                              • May 2008
                              • 3836
                              my car leans to one side when you pull the e-brake up.
                              www.instagram.com/snwmble
                              #snwmble
                              Current:
                              '05 BMW M3 - Silver Grey/Imola Red
                              '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
                              '15 Mini Countryman - Blazing Red/Carbon Black
                              Past:
                              '01 Audi Allroad - Light Silver/Platinum Saber Black
                              '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
                              '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
                              '90 BMW 325i - Schwarz/Tan sport *Sold*
                              '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
