what's wrong ?
  • m0nyet
    • Aug 2004
    • 5
    what's wrong ?
    hey ppl,
    i hv 85 auto 320i as my daily driver. recently i notice that in the morning the gear change from 1-2 takes longer time than before. it rev till 4-5K rpm b4 enggage to 2nd. but once its running, the gear change is normal again. no power lost. any clue ?? i did an atf change recently but still the same thing happen.
    is it telling me i need gearbox overhaul/replacement ??
  • bwanac
    • 3354
    Did you check the ATF level after the change?
    I think it sounds like you need more!!!
    • m0nyet
      • Aug 2004
      • 5
      fluid level is correct. checked it with engine running and its between min/max point. what really puzzle me is that it only happen with the engine cold or after u left ur car park for 3-4 hrs. :(
      • M-technik-3
        • 18946
        change the fluid and filter then see what it's doing.
