before i got the SMT, i wanted to do the 535i AFM swap for fun. The AFM took forever to arrive, and i had the SMT6 long before the 535i AFM arrived...
anywho, i was gonna proceed like normal and buy another 325i afm to swap circuit boards... but wait a sec - i have an SMT6, why do i need to swap boards?
so i plugged in the 535i afm, fired up my car... and it started! but stalled quicky. I was a little fustrated that i couldn't keep the thing on long enough to see what voltages it was putting out. I went away from the project for a bit, then had a bright idea.
I noticed the stock 325i afm puts out about 1.33 volts at idle. So, i took the afm cover off, started my car, and noted where the afm's pickup-arm was. I took the 535i afm, plugged it in, and moved the arm to the same spot. It read the same voltage.
I was quite dumbfounded why it shouldnt work if they both put out the same voltage. So, with the 535i afm hooked up, i started my car and noticed that the arm wasn't moving to the same spot. I manually held the arm on the 535i afm to the spot where the 325i afm would be. Car idled perfectly.
I then noted the differences in voltages and setup a basic map on the SMT6 to compensate. I started the car again, and voila! perfect start and almost-perfect idle.
I drove around a bit and noted what the O2 sensor was telling me. After making a bunch of adjustments, the car runs within 13.5 - 14.5 MOST of the time. At the higher rpms, it leans out slightly.... I think i need to put my larger 19# injectors in there to add some more fuel for all the new air that's comming in =)
oh, and also, i have a big ass K&N attatched to that AFM... the sound is unreal. I've never heard a 325i before with a K&N. It just makes a loud growl from 4K to redline. Beautiful!!
Once i get a digicam again, i'll prolly take some pics. I need to get my piping straighted out... i'm currently using alot of duct tape. Also, my bracket to hold the 535i afm on is made out of duct tape =)
I will be constructing something made out of steel soon enough...
Aside from the kick ass sound, i think it felt slightly stronger. Not a whole lot, but it was noticeable. I'm gonna go race my friend with an accord and see if anything has changed...
