Does anyone know why I cant go into first gear?
  • mikeinsanmarcos
    • 44
    If I am driving along, all gears are smooth as silk but when I am coming to a stop, I have to completely stop then push in the clutch and then I can put the car back into first gear. Anyone know why this would be? I have already checked the clutch stop position and that is not the problem.
  • M-technik-3
    • 18946
    Sounds like a worn synchro.
    • mikeinsanmarcos
      • 44
      Hmm.. Is this an easy thing to replace if I remove the tranny?
      • M-technik-3
        • 18946
        Depends but I can't diagnois a car without looking at it. It's best if someone actual looks at it prior to just arbitralar swaping parts.
        • mikeinsanmarcos
          • 44
          got it, thanks!
          • FrustratedMunky
            • Apr 2004
            • 360
            I also have someone of the same situation, except it isn't so bad as me not being able to get into first, it just feels like i have to push very hard and somethings holding constant resistance against me shifting from N to 1. If you find out what it is, please update us.
            '91 E30 M42 DIAMANTSCHWARZ
            • Super Eta
              • 1884
              i can hit my shifter consoles and if i wanted hard enough to leave indents. LOL
              Its like Jello when im shifting.
              • James Crivellone
                Head Janitor
                • 6305
                :roll:
                • rayz
                  • 494
                  same problem here. at red lights, I have to put it into 5th then 1st. thats the easiest way i found. sometimes anyother gear will do, before putting into first.
                  FOKAI DA'MA'SHI'I ENSANE GRAPPING INT.
                  • Super Eta
                    • 1884
                    :roll:
                    what?! 8)
                    • hamann318is
                      • 3382
                      Our Jeep wouldn't let you go into reverse unless you double clutched it. It was a 99, and it was always like that.
                      Does double clutching help?
                      The BMW 318 is back. With a vengeance.
                      • mikeinsanmarcos
                        • 44
                        No, I have tried many things and it just will not go back into first until I come to a complete stop, then pump the clutch when stopped.. I am going to replace the tranny fluid with some redline D4 synthetic and see what that does, but I expect I will need to open it up.
                        • RedBaron86325
                          • 386
                          The new fluid may very well solve the problem. If not, I have a used tranny sitting in the garage (Escondido) if you should happen to need one.
                          Don't forget the good things Hitler did.
                          • mikeinsanmarcos
                            • 44
                            Sweet, I will let you know!
