i transmission on e engine?
  • timothy100
    • 125
    Can a 5 speed transmission from an 88 325i be hooked to an 86 325e? I remember that there is a certain way that will not work, I just can't remember which way it is. I tried searching already...
    Thanks
  • Jordan
    • 12912
    The i tranny doesnt have the mounting provisions for the 2 sensors on the flywheel that the eta engine needs to start/run.
    https://mtechniqueabs.com/
    • timothy100
      • 125
      Okay thanks for the info. So there is no way to get it to work?
      • James Crivellone
        Head Janitor
        • 6303
        yep what jordan said, you can however use an eta transmission on an i motor
