Replacing Camshaft
  • GreekDriver
    • 100
    Replacing Camshaft
    Our E34 M20 needs a new camshaft. It's worn. Not really worn, but worn. Everything else looks good.
    What parts would be smart to replace while doing this? What seals and stuff will I need to order?
    Thanks!
  • Jordan
    • 12916
    Full rebuild of the head.
    12 new rockers, 12 new valve stem seals, 2 newrocker shafts3 angle valve grind, new cam seal, new "doghouse" seals, resurfaced head.
    That is the minimum amount of work I would do if the head is going to be pulled.
    https://mtechniqueabs.com/
    • GreekDriver
      • 100
      Oh, and it leaks oil, from the bottom. Oil Pan Gasket? What other gaskets should be replaced that aren't that difficult?
      • GreekDriver
        • 100
        12 new rockers, 12 new valve stem seals, 3 angle valve grind, new cam seal, ne "doghouse" seals, resurfaced head.
        Damn, the car has 70,000 miles. I guess I'd look into that, all the other parts look good though. I'll check the funds.
        • Jordan
          • 12916
          If the cam is worn enough to need replacing I would be VERY worried about the rest of the engines internals.....
          • M-technik-3
            • 18946
            How did you determine that this cam was wearing prematurely? Did you have a way of measuring the lift and duration of the lobes? Or are you just taking a wag at it?
            • Den
              • Mar 2004
              • 162
              BMW cams typically last a lot longer than 70k miles, more like 200-250k. I would guess that either your M20 has an oil starvation problem in the head or it has a lot more than 70k on it.
              • AdamF 88iS
                • 2051
                True story.
                Adam Fogg- '88 M3
                Common sense- It's the new 'gifted'
