Clunking from the rear question...
  • audiquattrot
    • May 2008
    • 3836
    Today I went and replaced my bad rear shock mounts, in hopes that it was the culprit of my clunking from the rear of my car.
    Just to give you a quick synopsis, a couple months ago I had to replace some hard brake lines right above the rear subframe. In order to get to them, I needed to remove my exhaust and drop the rear subframe in order to gain access to it. After reinstalling everything, I was getting a rear clunk, almost as if something in the suspension had play....happens when the car jerks in a forward/backward motion. I took the advice here, and replaced the worn rear top shock mounts which were in fact shot.
    I took it for a test drive today, and the clunk is still there. The shocks are new, which I replaced several months ago along w/ the springs. I guess what I wanted to find out is what other potential areas should i be looking at? Is there any visual way to see if my rear subframe mounts are bad? I had the car up on the lift, and were trying to see if there was any play in them.....but it was tough to diagnose. Visually they look fine. I really want to convince myself that I reinstalled something wrong, but I had a couple friends check it out....and everything seems to be tight.
    Advice needed. Thank you!
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
    The car is 18 years old, so it is safe to assume that the subframe and trailing arm bushings need replacement as well as the differential mount. In a like manner on a car of that age the transmission and motor mounts are suspect. Any of those could cause a clunk when the drive train loads/unloads.
    • audiquattrot
      • May 2008
      • 3836
      I agree....the only thing i do find a bit odd is that the clunk happened after I disassembled & reinstalled everything. I'm pretty confident w/ the work I did, I just hate not knowing exactly where the problem is coming from. I even brought it to a shop, and they themselves were baffled. I'm really trying to avoid spending a lot fixing things (that don't necessarily need to be fixed), simply b/c I've misdiagnosed it.
      #snwmble
      Current:
      Past:
