Electrical issue: passenger windows won't move
    this is on my '86 325e with power windows..
    both driver windows work perfectly, but the passenger windows won't move and are stuck in the up position (thank god.) i already tried swapping switches and fuses, none worked. what would be the best way of troubleshooting this problem?
    WTB: early e30 sedan front doors
    Its most likely a motor or regulator thats toast. I actually have the same problem with mine right now (thats why in my auto-x sig, the window is up)
      Really? I'd hate having to deal with that, lol.
      I figured it was electrical since the driver's side works flawlessly every single time.. it would be weird if that side is perfect and the other side is completely fooked. I guess it's very possible though.
        "driver windows work perfectly" makes me think this is a four door car. While it is possible that both passenger window motors failed at the same time, a more likely scenario is a electrical fault at the switches on in the harness that isn't supplying power to the doors.
          did they both stop at the same time?
          Originally posted by codyep3
          I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
          2001 silver/Blk 325 cabby. SOLD
          2002 325xit Sil/blk. SOLD
          2010 F650gs twin
            neither window has worked since i bought the car. poor thing :(
              It could be the electrical connectors/pins in the door jams, or you have 2 dead window motors. Pull the rubber boots in the doors back, pull the connector back, spray electrical contact cleaner, re-attach and try them. if that does'nt work, you will need to pull the door trims and check the motors.
              2010 F650gs twin
