Has anyone had experience w/ these E30 subframe stabilizers from ebay?
  • audiquattrot
    • May 2008
    • 3836
    thoughts? I have a slight clunk in my rear subframe, and the cost of having the bushings replaced probably exceed the cost of the car. I'm looking for a cheaper alternative for the moment until I can fund the replacement of the bushings. Has anyone used these before? I wanted to know if they may help the issue I am having...assuming my bushings aren't completely annihilated.
    http://cgi.ebay.com/ebaymotors/ws/eB...AQ:MOTORS:1123
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
  • E30_fiend
    • Apr 2006
    • 7348
    actually I have used them and realistically, they do a good job, The problem with the stock bushings is that they have gaps in the rubber which allows for subframe flex. What these do is they fill the gaps which in the best case just eliminates most of the subframe shimmy. I like them and they are a cheap and easy alternative to the race or street subframe bushings.
    Taylor
    • e30this
      • 3580
      My buddy made a set of them out of PVC plastic pipe.
      you can do it for 1/4 of the cost of what they are selling them for.
      • peerless
        • 285
        2" ABS pipe, you can make the same thing in minutes for next to nothing.
        Also if your subframe bushings are old, soft, and collapsed, these really are not the answer. This would be a modification you would want to do when you install new ones.
        I will be doing this soon. I was going to go poly, but I got a set of brand new ones from the dealer for free. Stick some ABS up its ass and into the car, should work great for what it is.
        • NC325iC
          • Mar 2004
          • 6565
          i wouldnt call it a permanent solution, if youre looking for something temporary before you do the job right then go for it. If your bushings are bad sticking peices of plastic in the holes wont solve it for long.
          • audiquattrot
            • May 2008
            • 3836
            thanks for ur input guys! I might try it out for the meantime since there are bigger issues I have to attend to on this car.
            #snwmble
            Current:
            Past:
