Air... Replaced all vacuum lines and gaskets for upper and lower intake manifold
Fire... I am only getting spark on cylinders 2 & 4, 1 & 3 are not sparking
Fuel... New fuel filter, no leaks anywhere, fuel in the lines at the injectors and I can smell fuel when cranking
Any ideas on where I should look?
At one point, I got injector codes of 2 & 4, but I swapped injectors with 2 & 3 and the codes went away...
History with the car... sat for about 2 years... according to seller, it was running when it was parked, but I do not believe it.
What are some common things that go out relating to starting problems?
So far I have only found something regarding the fusible link leading from the battery the rest of the vehicle...
