engine swapped car wont start help???
  • Sean T Sat
    • May 2008
    • 102
    i swapped an engine 87 325 is motor and its all hooked up but when i turnthe key the starter just clicks. sometimes just once and all the car warning lights shut off or sometimes like 4 clicks then nothing. it wont turn over and was wondering if there was something wrong with the starter or etc. maybe the wires are wrong so if someone knows the colors or has a pic of there starter that would be much obliged.
  • 92 mtechnic cabrio
    • 4907
    what car did you swap it into?
    did you swap the ECU?
    R.I.P 07/01/09 - 04/23/10 :(
    • lordofthewaters
      • Oct 2005
      • 714
      Did you replace the engine ground? Missing/bad ground on oil pan will give this symptom.
      Sarcasm is a body's natural defense against stupid.
      When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
      "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
      Old age and treachery will always overcome youth and skill.
      • Sean T Sat
        • May 2008
        • 102
        into a 90 vert and yea i swapped the ecu
        • Sean T Sat
          • May 2008
          • 102
          yes ill clean the ground now and try that but i did replace the ground
          • lordofthewaters
            • Oct 2005
            • 714
            Sometimes it'll look fine, but if you use your jumper cables and clamp one neg on the drain plug, and the other on the strut tower nuts, it'll be a good test, to see if it'll crank.
            • Sean T Sat
              • May 2008
              • 102
              ok i got it to crank but now the fuel pump isnt gettin power:hitler:
              any ideas????
              • lordofthewaters
                • Oct 2005
                • 714
                Relay?
