Anit-lock light is on - anything to worry about?
  • Jand3rson
    • 37587
    The anti-lock light has been on in the E30 ever since I bought it, but there doesn't seem to be any problems with the brakes at all, they seem fine. Loose sensor or something maybe?
  • george graves
    • 19996
    I have this same prolbem, I think the cog wheel might need a good cleaning....
    Originally posted by Matt-B
    • James Crivellone
      Head Janitor
      • 6302
      Could be the cog, bad sensor, bad ABS Computer, loose ground, Bad hydralic actuator, etc.
      do you want ABS? I plan on putting a switch on mine for instant on/off, I would check connection harness's to the sensors first, the two under the rear seat and the two under the hood
      • Spaz
        Crazy Canuck
        • 2276
        well there is nothing to worry about, regular hydrualic brakes will work just as normal.
        Cam .W '91 325is
        Spaz's 1991 Alpine White???? S52 Build Thread...
        • jrdn223
          • Jun 2004
          • 138
          yea mine was on when i bought the car. mechanic said it was the left front speed sensor. replaced that and it was still on. so now he's sayin its the actual abs computer that suposed to tell you when something is wrong is the thing thats wrong. hmm.. kinda funny actually. he says hes seen that alot in older bimmers. i'm leavin it alone cus brakes are fine.
          • James Crivellone
            Head Janitor
            • 6302
            weird, I have working ABS on both of my cars, the project one even has teh M3 ABS System in it without issue.
            • bimmer8604
              • 3017
              i had the problem on my old car. my fix was to replace the fusable link in the little fuse under the steering wheel. its very easy to fix.
              -remove the ABS relay box from under the steering wheel. Its ontop of a metal box on the rear of it, just slide it over to the left and it will come off. Disconnect the harness. Open the box up, and you will probably see a broken fuse wire. Go get some fusable link of the same size, and re-solder in a new piece. This description is very vague, as I couldn't find it on BEN, but maybe if you just start poking around down there you will find the relay, its about the size of a 9volt battery.
              HTH
              Kyle
              1988 M3, 97 840, 99 XJ
              DILLIGAF
              • AndrewBird
                The Mad Scientist
                • 11898
                I still liked the time Jordan locked up his car doing 60 at 5 in the morning . Got to love no ABS. :)
                Andrew
                • James Crivellone
                  Head Janitor
                  • 6302
                  Originally posted by robbieosterman
                  Hey. if you manage to that, i've been interested in doing the same thing. Think you could help me out?
                  Yeah I will post a writeup when I do it, I am running the M3 ABS On my car, so it may be a tad different, however I am just tapping into the ABS Relay
                  • robbieosterman
                    • May 2004
                    • 199
                    Where is the ABS relay? In the fuse box or is it behind the dash where the computer is ... ? Ugg.
                    • James Crivellone
                      Head Janitor
                      • 6302
                      Behind the dash to my knowledge, I gotta check my notes
