Ok so my ongoing issue w/ rear clunk & popping noise still persists after replacing my rear top shock mount & inspecting my rear subframe bushing (which are in fact fine). The sound is almost as if something spring loaded, releases.....which usually happens when i pull the car in reverse. When the car thrusts forward it makes a sound like something is loose, possible brake assembly?
I noticed my rear brakes are due for replacement, and recently had all my rear hard brake lines replaced throughout....since they rusted thru.
Question I have now is, I had a buddy listen outside as I pulled from a stop....and noticed the rattle/clunk noise coming from my rear pass brake. Can anyone tell me what are potential issues that may cause this noise back there? Is it common for calipers to stick on these cars, and could that be a potential issue?
I'm not really sure what I should start replacing nxt. Thank you!
