diff change help
  • bobmaf
    • Aug 2004
    • 17
    diff change help
    i have a 318i e30 and someone has told me to change the diff for a little more speed
    which diff can i put into my car 1991 e30 318i like a 325i maybe or 320i ????
    cheers
    bob
  • kylebes1
    • May 2004
    • 2804
    any e30 diff will work, but do you have a 84-85 318i or a newer 318is?
    the 84-85 have a 3.91 LSD and the only thing lower would be a 4.10 or 4.27 and those things are rather costly.
    I do not know about the newer 318is cars.
    By the way I have a 3.73 LSD Large case and a 3.91 LSD small case for sell
    • bobmaf
      • Aug 2004
      • 17
      i`m not too sure what year the engine is i bought the car from a lad who changed the engine from 1.6i to 1.8i i will ask him
      i am wanting higher speeds so what diff shall i put on as i have access to quite a few e30`s as i work at a car scrap yard uk
      cheers
      bob
      • BavarianBimmer
        • 951
        It's a newer one
        M40 powered ;)
        EDIT : Your car is probably equipped with an 4.45 or an 4.27 open diff
        1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
        1997 E36 328iT
        1990 E30 325iT 24v SOLD
        1989 E30 325i 2.7i M-Technic II SOLD
        • bobmaf
          • Aug 2004
          • 17
          well i must admit its quick for a 1.8i
          i was giving it a blast the other day (i was on the track if police ask) i managed to get upto 125mph but that was really pushing the engine it would probably top out at 130
          if i put a 325i diff on it would that make a difference in top end ??
          cheers
          bob
          • BavarianBimmer
            • 951
            What do you want ?
            Quick acceleration --> lower top
            or
            slow acceleration --> higher top
            I'm confused
            1997 E36 328iT
            • bobmaf
              • Aug 2004
              • 17
              top end speed
              not fussed about set off
              just to be able to carry on going when others hit there rev limiter
              cheers
              bob
              • Mike 91 318ic
                • Jun 2004
                • 429
                Originally posted by BavarianBimmer
                It's a newer one
                M40 powered ;)
                actually I'm pretty certian it's a 4.10 open... 4.27 are only on 318ic and the 4.45 is on the E36 318ti which will fit btw.
                M
                • BavarianBimmer
                  • 951
                  maybe try something with a 324TurboDiesel diff (3.25)
                  but it'll hard to find there in the UK i guess
                  or an early E30 323i 83-84 (3.23)
                  some guy has told me that the Euro spec eta till 9/1985 was equipped with an 2.79
                  correct me if I'm wrong
                  but your M40 hasn't enough power to reach high top ends with the eta one
                  1997 E36 328iT
                  • BavarianBimmer
                    • 951
                    It's a newer one
                    M40 powered ;)
                    M
                    keep in mind it's an euro spec 316i ;)
                    it's pretty much different as a US spec
                    I've heard the 4.45 was installed in the late E30 316i
                    1997 E36 328iT
                    • bobmaf
                      • Aug 2004
                      • 17
                      is there any way i can tell what diff is installed by looking at it i have the use of a ramp so that aint a problem
                      off topic i heard a while ago on another forum that you can change the throttle body the air intake and injectors from a bigger e30 like 325i or 320i into a 318i is this true and what difference will it make ?
                      also off topic would it be easier to change the engine from a 325i or 320i into my 318i if so what do i need to swap engine diff tank ecu ????
                      cheers
                      bob
                      • BavarianBimmer
                        • 951
                        cheers
                        bob
                        there is on the left or the right side a tag with some stamped numbers like 410
                        I think you've heard about to swap by an 325i car the afm by an 535i afm
                        for an M20 swap you'll need : 6 banger drivetrain, wiring harness, rear disc brakes and of course the ECU and another things that i forget
                        1997 E36 328iT
                        • bobmaf
                          • Aug 2004
                          • 17
                          nah forget changing the engine then it sounds like alot of time
                          is there any other way of adding power by swapping changing or modding stuff on my car ???
                          your being a really big help
                          cheers
                          bob
                          • BavarianBimmer
                            • 951
                            don't forget power cost money
                            the easiest way is to buy a chip
                            or do an M42 swap ( DOHC 16v i4 engine)
                            and you've a high MPG too :P
                            ps are you from the New Brunswick area ?
                            1997 E36 328iT
                            • bobmaf
                              • Aug 2004
                              • 17
                              mine must be the m42 318is as it does 125mph 130 if pushed hard in my book it say the m40 will only do 117mph
                              you said a 16v engine from what year and model as we might have one
                              no i`m from the uk
                              cheers
                              bob
