Has anyone ever painted there interior with duplicolor paints or any other paints? Dose it work on leather? how dose it look? How dose it hold up?
Duplicolor Interiors.... Pics wanted!
I would use a leather dye on leather (or shoe polish...sounds crazy but its good for those scratches and scuffs). You should go to a local upholstery shop and chat with them. I wouldn't recommend painting you dash all wacky colors. Keep it period correct, ie: 80's style. If you want to change the color of the dash I'd go white and use cocaine to do it (very very 80's :nice:) -
i painted my tan fabric inlay door panels black with dupli color black vinyl spray.....the vinyl must be cleansed, preferably with soapy water and a sponge or scotchbrite lightly....then it can be painted. the vinyl comes out good paint is strong and flexible enough for the panels. it looks so close to stock if you didnt try and scratch at it you wouldn't have known.
the fabric on the other hand came out good at first, but after about a year you can see where the wear marks from opening and closing the doors.
On leather, paint doesn't work...you'll need a dye.Comment
you can kinda see it here
use SEM color coat(spray). most auto paint supply stores will carry it. also get the SEM vinyl prep spray while youre there. give everything a good soap and warm water scrub. then hit it with the vinyl prep spray, then bomb it with a lot of very light coats of the color coat. i promise you if done right it wont go anywhere and will look OEM.Comment
