Once again, my 85 318i, no lights come on and no chime when either door opens. The lights work too when turned on manually. Any ideas? It could be the buttons in the door jams but BOTH don't work at the same time???
No light when open door
Tags: None -
still not working....
ok, I removed and inspected both switches for both doors, and they look great. I cleaned them anyways and made sure they had a good ground. Still no light when I open the door. This is getting very annoying cause I hate having to fumble in the dark for the light. is there some sort of switch/relay for this somewhere??? what should I do next? Neither light will turn on regardless of either door open or light switch position.Comment
where is this located, what does it look like, and how much are they??Originally posted by rs4pro3Maybe check the delay relay, I had some problems with the lights and after I replaced that relay they worked fine.Comment
Under the driver's side speaker, I put a used one in, so it was free. Check the wires on it, as I had the central locking plug corrode that is right next to it(why you'll find the control box under the dash). I rewired it but I think I left the box alone as at that time the lights were working.85 325e 2.7 ITB'd stroker
...most likely its just the fuse. Check for blown fuses in the fuse box...I forgot which one it is, but there are only like 20 of them. I say check that first.- 2000 Audi S4 Stg 2 (sold)
- house (bought)
- 1997 Civic Hatch (shaky but driveable)
- 2010 Sportster 1200 Forty Eight Ed. (vroom)
- 1991 318is S50B30 (TBA)Comment
i had this problem, i just swapped in a new light assembly and it worked fine.Comment
Are you high?Originally posted by clutterbucker...most likely its just the fuse. Check for blown fuses in the fuse box...I forgot which one it is, but there are only like 20 of them. I say check that first.James Peacock
WWFSMD?Comment
fuse??
are you insulting me???Originally posted by clutterbucker...most likely its just the fuse. Check for blown fuses in the fuse box...I forgot which one it is, but there are only like 20 of them. I say check that first.Comment
ok, I pulled out the black box that the door sensor runs to, and I pulled a plug out of it and it measured 16-17 volts with the door open and 0 when closed. After fucking around with it a little and putting it all back together, the passenger light comes on when opening the the passenger door, nothing happens when opening the drivers door. wtf???? the drivers door switch works obviously.Comment
bumpComment
the light comes on when opening the passenger door. the drivers door light is burnt out.Originally posted by mjc85Have you checked the bulb ? :?Comment
