Went to change my diff fluid the other day and found that the fill plug is corroded and I cant get it out!
I can't fit my 10mm hex bit socket into the hole because of the corrosion. I was thinking of filing down 10mm I had, but the hole looks allmost circular. Can't hammer it in because I'm using this (not enough room between the diff and the spare tire well)
My friend suggested that I tap it with a left hand thread, and remove it using a left hand bolt. Sounds like a good idea, but I'm not sure if the plug is too hard to use a tap on, or if there is enough room between the diff and the spare tire well.
I tried using some penetrating oil that usually gets corrosion off, but it did no good. Any recommendations? :?
