Power for Maplights?
    Okay... so i need to get some power to my maplight mirror that is not a big deal just rob some power off the check panel.
    Except how and which pin?
    Thanks
    Re: Power for Maplights?
    Thanks
    Year of your car?
    My Bentley shows constant 12V on the red/green wire for '84-'86 models and red for '87-90 models.
        Thanks guys. i did a google and got nothing maybe i should have searched harder. never the less.
        Thank you for your help.
        Its an early production 86 model. (11/85)
          i just wired mine to a light purple wire, it comes on with the key. solid purple (there are two, use the lighter one) if you have a late model with an srs active check control.
          Dan
            I'd tie in the power from the door lights, so the map lights came on when you opened the door. Super trick. :)
              if i wired them to lets say the dome lights would i be able to turn it on and off. :D
                Well, you'd have to have it set up so it always had 12V but the lights would come on when the doors were opened. With a little wiring trickery inside the mirror it could be done. :)
