Need a picture of a receiver/dryer!
    Can somebody please take a picture of their receiver/dryer? I need to see where the pressure switch goes in... there are two threaded holes on that side.
    Originally posted by Gruelius
    If you look at the top of the Dryer with the Valve facing You. The Green Pressure switch threads in right below the Valve.
    Then the Other Pressure switch threads into the opposite side but of the center of the dryer directly opposite the Popout valve.(either side of the looking glass) Pop out should be on the right when the valve is facing you and the Other switch on the left.
    85 325e 2.7 ITB'd stroker
