much better economy after some cleaning/upgrades
  • natorious
    • 672
    so my chipped autotragic 325i sedan has jumped up quite a bit in the milage department
    on my last 600 round-mile trip i averaged 27.14mpg up from last weeks 20.1mpg (calculated by mileage compared to fill up method not OBC but my OBC is less than .5 mpg off of my calculation)
    i swapped out my stock injectors with a set of freshly cleaned 95 M3 ones fixed my throttle body coolant leak and installed a new cap and gasket on that fitting, put in a new fuel filter, and cleaned the hell out of my throttle body (looks brand new now)
    gas milage sucked for about 150 miles after the injectors were installed but once things settled in its been running so much better... two of the stock injectors were filthy and one was partially clogged i think...
    what else effects the mileage...
    i am going to be doing the o2 sensor and the valve adjustment this weekend (weather permitting)
    in case anyone is wondering the car is basically stock except the injectors, hatge design A 16s, and a venom rev II chip still working on getting it all cleaned up and fixing stuff before mod time
  • ///M42 sport
    • 3952
    stupid question, but how do you install injectors?
    • BavarianBimmer
      • 951
      pull them gently out and install the new ones WITH new oiled o-rings
      1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
      1997 E36 328iT
      1990 E30 325iT 24v SOLD
      1989 E30 325i 2.7i M-Technic II SOLD
