door plugs
  • BMWM5LOVER
    • May 2004
    • 261
    door plugs
    Ok guys, on both doors of my car i need to replace the wiring plugs that come out of each door, due to corrosion. where can I buy those plugs, so that i can solder them on the wires coming from the door?
    Due to this, My central locks, Pwr mirrors, dont work, and my passenger side window, only wants to work when the door is fully opened, even hos there is no disconnected wires. than you.
    1991 BMW ///M5 .:Black on Black:. - Modded
    1988 BMW 325i .:Zinnebarrot on Black:. - Modded
    1999 Volvo V70R AWD .:TI Silver on Black:. - Modding has begun
    1999 Subaru Legacy AWD/5 .:Green on Grey:. - Modded Rally Style
    1990 M20iS Alpwhite II- Sold
  • BMWM5LOVER
    • May 2004
    • 261
    help, im looking for just the door connector with some wires that i can connect to mine
    • Jordan
      • 12913
      all the wires are press in prongs. They have flex tabs that lock into grooves in the plastic connector.
      Use a really small jewelers flathead to push the tabs flush and back the prong out. Its gonna take awhile so be prepared.
      The connector most likely has a part number on it, if not someone with a ETK can help you.
      https://mtechniqueabs.com/
      • rs4pro3
        • 5808
        I just looked in the ETk and you can't buy the plug prewired, you'd have to buy the plastic plug itself then all the individual plugs.
        What year is your car as I can sell you some non corroded used plugs off an 84 325e.
        85 325e 2.7 ITB'd stroker
        • BMWM5LOVER
          • May 2004
          • 261
          can u post the part numbers please. Ive also got the ETK, but not too sure how to use it. D u have a diagram showing what each one is for, on both sides of the plugs?
          thank you
