Injectors not firing.
  • 2002maniac
    • 4260
    I just swapped in a low miles M42 and now i cant get it running. Fuel pump is running, has fuel pressure, I pulled the fuel rail out and cranked the motor and they didnt squirt a drop. I have a spare set of injectors, but I doubt all 4 would be stuck shut. I think it's an electrical issue. I double checked every connection and all the wiring is hooked up and correct (I believe). The motor came from a running car that i parted almost a year ago and was installed with the original engine harness in place. Anyone have any leads to help in the troubleshooting process?
  • archemedes
    • 125
    computer getting crank signal?
    • 2002maniac
      • 4260
      How would i go about checking that? Wouldn't the coils not fire if this were the case?
      • archemedes
        • 125
        mine fired the coil, but not injectors when it came unhooked
        • 2002maniac
          • 4260
          Turns out I had the fuel lines (feed/return) switched. New motor runs great now!
