which wheel bearing?
  • MGB GT
    • May 2008
    • 37
    I have a front wheel bearing going out and have raised the car to try and rock the wheels but both are tight. the whirring noise goes away on right turns and gets worse on left hand turns. Any ideas on which bearing it is?
    drivers side or passengers?
  • peerless
    • 285
    Replace them both, then you can't miss.
    If one is shot, you can be assured the other is right behind it.
    • Uber E30
      • 1409
      Should be left because more stress/friction=more noise
      -Alex
      • SpecM
        • Oct 2005
        • 4531
        no, left turn = stress on right-side bearing
        right side
        1989 cirrisblau-metallic 325i
        • AndrewBird
          The Mad Scientist
          • 11898
          What do they sound like when you spin them? Pitted bearings will cause a grinding noise, but not necessarily any play in the wheel.
          • De //m3
            • 165
            If you only have cash to do one, it is the right side bearing. almost guaranteed the other will go within 10,000 miles, mine was after 4,000.
            The check:
            If its louder when you brake its in the front, accelerate = rear
            If its louder in right hand turns its the left side, left turns = right side
            think about where the weight transfers, but if you can afford, don't even think about replacing just one.
            2001 330i - In the garage.
            1986 335is - 325e with Euro 735 M30B34, Under Construction.
            1989 E30 ///M3 - Sold.
            1975 2002 - Sold.
            • MGB GT
              • May 2008
              • 37
              thanks guys,
              Unfortunatly I'm in residential real estate so I can only afford to replace one at a time.
              I thought that for sure it was a front wheel bearing, so I ordered one, but it makes sense that the whirring noise gets worse on acceleration and not braking. At least the rears are lwss than the front.
              Tom
              • e30:)
                • 728
                but more of a pain,
                • SpecM
                  • Oct 2005
                  • 4531
                  Originally posted by e30:)
                  but more of a pain,
                  much much more!
                  I'd rather pay the difference for a front one!
                  If you do the rear go ahead and get a new hub too
