my 1988 325ix was running fine till the other day .i went to go to lunch and it would't start i'm getting no spark and the coil is checking out just fine. any help would be appreciated:crazy:
car won't start help please
What is checks out? You know you're getting spark? You've pulled a plug and seen it spark?
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
Old age and treachery will always overcome youth and skill.
everybody always wants to go and blame the ecu right away. the fact is they seldom fail. you've got alot of troubleshooting to do before you get anywhere near isolating the ecu. you need to give more info first of all
ie. is the engine cranking?
are you getting fuel?
i would check first for a loose or broken connection at the crank sensor then if that doesn't work check if your main relay is working
'89 Alpine S52 with goodiesComment
The engine does crank fine. I do believe that I am getting fuel but I will check again tomorrow. What would the crank sensor have to do not getting spark out of the coil though? And where is this main relay? Maybe it shit the bed but I don't know where it is. Do relays just go out of the blue?
ThanksComment
Oh man.
Fuel pump relays,
Fuel Pump,
Do you have gas?
What was the LAST thing you worked on?Yours truly,
Rich
Originally posted by Rigmasteryou kids get off my lawn.....Comment
the ecu gets its signal for tdc from the crank sensor it uses it for ignition timing. if theres no signal from the crank sensor the ecu wont energize the coil the main relay powers the cps somehow. well thats how it looks on the etm i didnt read it that closely and i dont have it with me now to look again... so i may be at least partially full of shit. hope this helps somehow though.
do you have a bently and electrical troubleshooting manual?
e30tech has a thread in the faq/diy about etm's in .pdf format i dunno if the links stil work but its a must have
Holy shit dude...
The ECU uses the signal from the CPS to turn the coil on/off. The power signal to the coil cannot be read with your $20 voltmeter, it cycles on/off too fast. And just because the coil's resistnce checks out, doesn't mean it can provide a spark. And yes, relays can go bad overnight.1989 cirrisblau-metallic 325iComment
this forum rules
:pwell you guys you were right . i took off the sensor and the wires were intact but not that well so i cut the wires then cleaned out all the factory epoxy then cut the hard plastic sheathing off to expose the little wire inside the sensor i then sodered on new wire extensions to the sensor and tried it out it works great and i saved about $120 dollars for a new one thanks again guys for your help:up:Comment
