It all started off with a vibration noise from what sounds like under the center of the car. The noise would only last from 1-1.5k RPM in first gear. It would stop or not happen if i give the car more gas. I'm thinking that has something to do with either the exaust system or heat shield. I've been so busy lately that i just let it go for the time being.
Now i'm getting a strange medium-high pitched creeking shimmering noise coming from the right rear end of the car. it starts at about 2-2.5k RPM and stops at 3k RPM in 1st and 2nd gear but increases to a poping noise if i add (a lot) more gas. I usualy switch gears at around 3k RPM so i'm getting this noise just before i'm switching.
Is my diff going? Maybe a bushing or shock mount? Awhile ago when i had A control arm and fuel pump replaced and the guy said i needed new rear shock mounts. Could this be the cause?
