Q's for Turbo M20 guys...
  • golde30
    • 11464
    ok, so i want to throw a turbo onto my M20, and i want to know what mods i need to make to the car in order to make it work rite @7psi.
    i know i need:
    turbo exhaust manifold
    turbo charger(thinkin something small like a T3/T4 hybrid) w/wastegate
    intercooler/piping
    boost controller
    modified intake
    maybe a pop-off valve on the intake manifold to prevent overboosting
    modified exhaust system.
    what i need to know is, what kinda fuel system mods would be required to run this setup @7psi? and also will it work with my JC chip in the ECU? also will i have to change out the piston rings and headgasket as preventative maintanance? i know 7psi is pretty low, but i figure it will be about a 60-80 hp gain, and thats good enough for a daily driver. thanks for yer help guys.
    -cary
    IG: @Baye30
  • Jordan
    • 12916
    JimC chip = timing advance
    timing advance + boost = detonation
    https://mtechniqueabs.com/
    • diegom6
      • 4447
      Yup! Jordan is correct, forget the chip! will blow up your engine with the turbo.
      You need a properly sized turbo, depends how fast you want go, but judging from what are you saying I think a Garre T3/T4 with .48 A/R hot side for fast apooling( Ihad that one in the past) and something like a T4 housing with .60 A/R cold side.
      Oil lines
      Turbo Adpapter Header
      CUstom pipes
      IC
      19-24LB/H injectors
      FMU/ SUper FMU like Begi/cartech (adjustable)
      money
      ..................and patient!!!
      Later
      Diego
      Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
      • golde30
        • 11464
        FMU? fuel management unit? is this a standalone fuel system? sorry, my only turbo experience is with my nissan, and it was built for a turbo from the factory. i want to avoid having to use a standalone system, which is why i am keeping the boost low. i was hoping to get away with just an upgraded fuel pump, adjustable FPR, and bigger injectors...
        IG: @Baye30
        • golde30
          • 11464
          ahaa...yes, that makes sense, i guess if i do this turbo project i will have to sell my JC chip and get a stock one.
          IG: @Baye30
          • diegom6
            • 4447
            Originally posted by golde30
            FMU? fuel <a href="http://www.ntsearch.com/search.php?q=management&v=56">management</a> unit? is this a standalone fuel system? sorry, my only turbo experience is with my <a href="http://www.ntsearch.com/search.php?q=nissan&v=56">nissan</a>, and it was built for a turbo from the factory. i want to avoid having to use a standalone system, which is why i am keeping the boost low. i was hoping to get away with just an upgraded fuel pump, adjustable FPR, and bigger injectors...
            FMU standar ( don't recomend you this one)
            - Ihave this one and I hate it cuz is not adjustable!
            [/img]http://cgi.ebay.com/ebaymotors/ws/eB...category=34198
            Begi-Cartech Super FMU adjustable( I suggest you this one)
            http://cgi.ebay.com/ebaymotors/ws/eB...category=33553
            you can run up to 15-16 PSI with upgraded fuel pump and 24 LB/h injectoirs with this Super FMU with out major problems, stock ecu, but need retard timing
            • DanGillan
              • Mar 2004
              • 4061
              ill buy it!!!
              Dan
