Whenever I start up the 325 and turn on the A/C, there's a faint smell of gasoline... does anyone know what would cause this?
Gasoline smell in A/C?
Re: Gasoline smell in A/C?
is it only when you turn on the a/c or is it with the vents open, the heater on??Originally posted by e30MattWhenever I start up the 325 and turn on the A/C, there's a faint smell of gasoline... does anyone know what would cause this?
need some more info here. first off i'd check all the fuel lines. -
Any time the A/C is on, with the recirculate off, you smell it.Originally posted by Spazis it only when you turn on the a/c or is it with the vents open, the heater on??Originally posted by e30MattWhenever I start up the 325 and turn on the A/C, there's a faint smell of gasoline... does anyone know what would cause this?
"See, we're adding a little something to this month's sales contest. As you all know, first prize is a Cadillac Eldorado. Anyone wanna see second prize? Second prize is a set of steak knives. Third prize is you're fired."Comment
'89 325i auto.Originally posted by Brysondo you drive an 87?
ditto i was noticing this on my car along with a smell of gas all along the driver side of my car after driving for a while, ended up being the fuel line closest to the tank for me. but the smell was barely noticable with my ac on so i would check the line where the a/c grabs air from. make shure you do it while your car is hot though seeing as the lines expand when their hot so it leaks more. my line dosent even leak till its hot so checking cold can be unfruitfullfirst off i'd check all the fuel lines.Comment
I'd check to see how your injectors towards the rear are seated, once that happened to me and one of my injectors was leaking a little bit of fuel.
Maybe you could add some sort of UV additive to the fuel then take a UV light to see where it's coming from..? We do this for AC systems when refilling and to check for coolant leaks
