If you keep going at 120mph its doing 20mpg rpm, then stops in the 6 o'cock position at any speed above. (on a private road of course)
I take it the standard 1989 6cyc 320 did not in fact come equipped with infinite revs, everything is stock, including wheels with factory profile rubber (15in bbs). I believe it has the 4.1 non slipper diff. I found a online rev calculator for a 318is but not for a 320 so I dont know what it should be doing with the current setup anyway.
I am not brave enough to try and hold it long enough to see when the rev cut kicks in, my friends older 325 didn't seem to have one and blew itself up when he tried, so any ideas about where to start looking at this problem? I am going to take the cluster apart to inspect the batteries as I understand that's a common complaint, but does anyone know of other tach problem areas? Or can some other 320 owners tell me whats usual at say 70?
Thanks in advance for any suggestions.
