Ideas to remove stuck spark plugs
  • Court M3
    • Jan 2004
    • 6713
    Was going to change my spark plugs today and couldn't get the dam things out. Feels like they are frozen in place. Anyone have any ideas on removal?
    Continuous For Sale Thread
    323i s50
  • lordofthewaters
    • Oct 2005
    • 714
    You could try soaking the plug in Marvel Mystery oil, then running the car to operating temp. then soak it again and try to turn the plug while it's still just barely warm. I've heard to apply heat with a torch, but I'd never try that.........
    Sarcasm is a body's natural defense against stupid.
    When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
    "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
    Old age and treachery will always overcome youth and skill.
    • Court M3
      • Jan 2004
      • 6713
      will do tomorrow thanks? What about using wd40?
      323i s50
      • StereoInstaller1
        GAS
        • 22679
        WD40? Why would you want to displace water?
        Closing SOON!
        Thanks for 10 years of fun!
        • golde30
          • 11464
          PB blaster, let it sit overnite?
          IG: @Baye30
          • AndrewBird
            The Mad Scientist
            • 11898
            Breaker bar as a last resort?
            • SpecM
              • Oct 2005
              • 4531
              PB = win
              1989 cirrisblau-metallic 325i
              • der affe
                Technical
                • Dec 2005
                • 8452
                yell obscenities at it while you get it out!
                pb blaster or like run it up to operating temp, re lube, repeat. try that a few times and it should come loose. when you finally attempt to remove it. make sure it is cold.
                THEN when you reinstall the new plugs, put a little squirt of pb on the threads of the plugs AND..........run a spark plug tap through the head to clean up any carbon gunk that is in the threads. that is usually part of the reason why they stick.
                • SpecM
                  • Oct 2005
                  • 4531
                  ^ good idea, but use some anti-seize. You can buy a little pack of it at Advance Auto for $0.99
                  • der affe
                    Technical
                    • Dec 2005
                    • 8452
                    anti seize is great, but you need to used A TINY AMOUNT!!!!!!!
                    or you can foul out the plug. if you think you have enough on the plug's threads, use half of that.
                    in all actuality, if you go with regular change intervals, the PB blaster will do just fine. it is when you wait too long that the anti seize is a must
                    • SpecM
                      • Oct 2005
                      • 4531
                      touche
                      • Charlie
                        kid tested, administrator approved
                        • 6686
                        You wanna leave half the plug in the block?
                        -Charlie
                        Swing wild, brake later, don't apologize.
                        '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                        FYYFF
                        • lordofthewaters
                          • Oct 2005
                          • 714
                          Any progress?
                          • Court M3
                            • Jan 2004
                            • 6713
                            Originally posted by lordofthewaters
                            Any progress?
                            too busy with work. will try this afternoon
                            323i s50
                            • M5wanaB
                              • Aug 2007
                              • 405
                              I had a problem like this, kind of. I had a plug seperate while installed. THe porcelin completely seperated from the metal and the center just came out and all compression was blowing out the hole. I tried to remove the remainder of the plug with a socket and it broke the nut off leaving just the threads in the head. A lot of pb blaster and a big ass Easy Out and that was the end of that bitch story. I guess thats what you get when you buy a car for $1300. lol
                              1991 325iC w/ 75k Original Miles, Brillantrot, 5-speed, 16" BBS RX's, Black Leather Sport Heated Seats, LSD, and Diving Boards for life!!!:D
