Window switch issue
    Window switch issue
    My window switches have quite working since i did a dash swap. Any idea on a solution guys. My turn signals are out too, but i think that has to do with the hazard switch not being plugged in. I'm pretty sure I plugged every wire back in, but does anyone have photos of the window wire connected under the dash? Yes i've looked at the wiring diagram, but I'm getting nowhere with that.
    Are you kidding me? That nerd doesn't even know how his dick works, let alone a car.
    One of the switches above the radio is the window kill switch, just connect it and thats it. If istill nothing just press it.
      That's not necessarily it. I did a dash swap and my windows haven't worked since either. I even put a new window breaker switch in. The fuse was blown that affects the windows and I replaced that but still nothing :( Radio doesn't work either, nor does the speedometer. All these things worked prior. So I traded all those things for a nice dash :(
      Well, posterity, you will never know what it cost us to preserve your freedom. I only hope that you will make a good use of it. If you do not, I shall repent in heaven that I ever took half the pains to preserve it.
      ~ John Adams ~
        ya, this is seeming to be the case. I have to try plugging in those switches tonite. Otherwise im in the boat with you. At this point I just want the blinkers to work because I could always switch to crank windows if I have to.
          ok, blinkers are fixed! Now I just need to figure out the windows! not sure I have the cutoff switch, did all cars come with it?
            Yes they did. It looks like your fog switch sort of. Its either the first switch on the front of the passenger side of the center console, or its above the stereo next to the hazard button,and rear defrost. It may have been removed though, and the wires soldered together.
            Originally posted by codyep3
            I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
            2001 silver/Blk 325 cabby. SOLD
            2002 325xit Sil/blk. SOLD
            2010 F650gs twin
              hmm thanks, i ordered another switch in case i cant find this one, lol
