Starter Difference? 325e VS 325i
    • 37832
    Well, my piece of shit Eta needs a new starter so I am going to just go grab one from the junkyard most likely. Is there a difference in the 325e starter VS the 325i? Can I put a m20b25 starter on my m20b27?
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
  • TimmyBigHands
    • 260
    I am by no means an expert - but I dont think you can. The ETA's flywheel is much different than the I flywheel.
    • James Crivellone
      Head Janitor
      • 6305
      I don't see why not, the mount should be the same as well as the gear on the flywheel is hte same
      however I am not positive, I didn't see any major differences mechanically between my 325i and 325e starter
        • 37832
        Have an extra one to sell me cheap James?
        Grover Beach, CA
        www.BimmerHeads.com
        • James Crivellone
          Head Janitor
          • 6305
          well i'm not sure if it works, and its kinda rusty from sitting in the parts car before I bought it,
          I can test it thurs
          • rs4pro3
            • 5808
            They will interchange, the 325i one is a little stronger then the ETA and on some models the wiring is different for the small wire. Latter cars use a screw down wire, where as early models use a spade connector.
            I have 2 known working 325e starters in the garage. $40 shipped and one is yours.
            85 325e 2.7 ITB'd stroker
              • 37832
              Well, I'm gonna pick one up from Ely. Thanks guys.
              Grover Beach, CA
              www.BimmerHeads.com
