Had the car in for brakes and a wheel bearing and had the shop look at the cooling system as well because it had just started doing this - temp. would raise while sitting at a stop light. From about the 1/2 mark to in the middle between the 1/2 and 3/4 marks.
The shop said the following:
Coolant a little low, at the bottom of the reservoir
Pressure tested and found no leaks, but cap is old and leaking
After topping off coolant, test drove and temp. gauge was fine
Checked fan clutch, good
Checked thermostat via radiator hoses, good
Hoses and belts all looked good
Recommend new cap and coolant flush
In the end they topped off the coolant and put a new cap on. The car ran good for about a week, I noticed some liquid on the ground a couple days ago, touched it. Didn't feel/look like oil. Today, the temp. starts doing the same thing. Sitting at stop lights it's starts moving up.
Any ideas? Would a flush help? Could they have missed a leak?
What's the safest temp. to let the engine get up to before (seriously) worrying about a cracked head?
