I have two e30s and I noticed that my 318i does not have rear sunroof drain pipes in the trunk like my 325i.
Question #1, do ALL e30s have front AND rear sunroof drain pipes?
When I pour water into the front sunroof drains on my 325i I see where the water comes out from the bottom near the front jacking point, there is a 1/2" by 1/4" or so slot for the water. I look under my 318i and don't see anything like it.
Question #2, are the front sunroof drains routed to exit at the exact location on the early and late e30s?
On both sides of my 318i between the front and rear jacking points on both sides of the car, there was a plastic plug facing the ground, when I removed the plug water came out on both sides.
Question #3, what is this plug?
Thank you!
Thank you!
