Terrible MPGs
  • GaryE30
    • 4791
    Terrible MPGs
    Okay here's the scoop. Car has recieved all regular maintenance within the last year. Its been running great up until this past weekend. I usually got about 300 miles per tank which is alright but nothing extraordinary (22 mpg).
    I seafoamed the car on Friday but only used 1/3 of the entire bottle, had a full tank of gas. I drove a bit around my hometown (50 miles) and then proceeded to return to work in Asheville (120 miles).
    Now I only have about 170 miles on my trip odometer and I'm reading about 1/8th of a tank or less left. I watched it the whole trip slowly dropping.
    I don't know what happened, but I've seafoamed my car before and got great results. This time the car runs the same, but has worse MPG.
    The car recently had a 71 deg C thermostat installed (because it was new and laying around... stupid me) and the temp gauge always reads about 1/8th from cold. Is it possible that the car is running so cold that its just running really rich and killing all of my gas?
    I need some help.
    Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
  • SpecM
    • Oct 2005
    • 4531
    that is possable, the temp gauge should sit about 1/4-1/3 in this weather
    1989 cirrisblau-metallic 325i
    • Kilomph
      • Oct 2004
      • 599
      Swap that stat out for the 80 deg.
      I'm getting worse MPG lately, too. I recently got my car up and running after letting it sit for a good 6 months, all new ignition/fuel/intake filters and regular maintenance pieces. After finishing the work I was averaging 25.8 MPG on the highway at 70-72.5 MPH on my 70 mile trip each way to Hoboken and back. Now that it's colder out, I've been averaging 20-22 MPG. My temp gauge still reads the same, I run the 80 deg stat. I thought engines produced more power when it got cold out. Does anybody have an explanation for this?
      Thread jack!
      • SpecM
        • Oct 2005
        • 4531
        nope, engines run better when they are hot
        they have more power with cooler AIR, but not the engine itself
        I say the bad mpg may also have to do with crappy gas? Maybe...
        • GaryE30
          • 4791
          I just ordered an 80 degree thermostat. It may not fix the current mpg problem, but I needed to be running warmer anyway. I'll also be checking my spark plugs, but they're only about 6 months old anyway.
          It could be crappy gas as well. I'll be filling up soon so we will see!
          • 87bimmerguy
            • Jan 2008
            • 123
            Check your O2 sensor...
            • PhillyG
              • 754
              Plus one, all that old carbon and shit going over it could have shot it out.
