What is the alternator supposed to charge at?
  • yoni
    • 468
    Hey guys
    so I'm thinking my alternator is overcharging (~14.8 )
    what is the alternator supposed to be charging at? (the is for a 325ix)
    Thanks guys
  • yoni
    • 468
    Come on...
    you guys know this
    • NC325iC
      • Mar 2004
      • 6565
      mine stays in the 13.5 range
      • yoni
        • 468
        can anyone else confirm what theyre alternators charge at?
        or if anyone knows what they're supposed to charge at - fantastic.
        • SpecM
          • Oct 2005
          • 4531
          should be 13.5-14.5
          14.8 is a little high
          1989 cirrisblau-metallic 325i
          • yoni
            • 468
            anything i can do to correct this problem?
            or is a new alternator in order...?
            • SpecM
              • Oct 2005
              • 4531
              the only worry I can think of is damage to the battery
              have it checked
              • StereoInstaller1
                GAS
                • 22679
                What are you metering with, and at what RPM?
                Closing SOON!
                Thanks for 10 years of fun!
                • robspeed325i
                  • 403
                  should be 14.4 max. the regulator is all you would need, and its only about $30 at autohausaz.com
                  • george graves
                    • 19998
                    14.8-14.5=0.3 volts. Multimeters can easily be off that much.
                    Originally posted by Matt-B
                    • robspeed325i
                      • 403
                      true...
                      • yoni
                        • 468
                        so what is the general concensus?
                        to just leave it be..?
                        i'll get it checked again, and see what it reads..
                        • twistednut
                          • Nov 2007
                          • 272
                          test it with a Fluke meter.
                          what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
                          • StereoInstaller1
                            GAS
                            • 22679
                            My specific consensus is that more data is needed.
                            A DVM is adequate, but what RPM and what conditions? 14.8 is a bit high, but nothing to worry about. Most alternators charge best just over idle to about 2500 RPM.
                            Closing SOON!
                            • SpecM
                              • Oct 2005
                              • 4531
                              alos, what kind of load did you have on the alternater? That effects it too
