steering column rattles on early model
  • jw 325ic
    • Sep 2006
    • 1360
    my 88 started rattling in the front. thought it was a strut at first but when i jacked up the front end and started checking everything out, i wiggled the front drivers wheel, saw and heard the steering column u-joint had some play and was rattling. is this common? i know on late models with airbags its a whole nother issue and has the splines etc which will rattle. but can i just go to the junkyard and get a good ujoint and replace?
    EDIT could it be #12 in this? the flex disc looking thing?
  • FredK
    • 14761
    Try seeing if that large nut on the column can be tightened. Mine was loose and causing a sound over bumps.
    • jw 325ic
      • Sep 2006
      • 1360
      thought that was late model?
