Help-Need warmer heat.
  • Devil Inc
    • Jan 2008
    • 802
    Ok, here's my issue. Last spring, I did the budget 2.7i swap and everything was awesome heat wise. Now, for some reason I do have half-way decent heat out of the floor and defrost vents, but the air coming from the dash vents is nowhere near the same temp as the other areas. I have not re-bled the system yet, but I will be doing that tomorrow. I've checked the coolant level, it's fine, all the hoses are in good shape, no leaks. Why is it that I have decent heat from the defrost and floor, but not from the dash vents? I've never had the dash apart other than to pull the cluster and put in the radio. Personally, the only time I use the dash vents is when someone is riding in the back seat. My temp gauge rides just above the 1/4 mark, which is where it did after the swap.
    The thermostat has been changed, so I know that is good, I replaced it with the standard replacement temp. My heater valve is good, I can here it clicking when cycling from cold to warm.
  • AndrewBird
    The Mad Scientist
    • 11898
    Possibly a tube came undone somewhere so cold air is getting in. The air flowing through the tube from the blower should suck some air in from an opening if there was one.
    If everywhere else put out hot air, then it has nothing to do with the cooling system.
    • Devil Inc
      • Jan 2008
      • 802
      Come to think of it, I tried the recirc. button, I don't remember hearing the flaps adjust. How hard would those be to check?
