Will this thing cause the right side-marker fuse to blow if it goes bad? Mine blow for no reason I have checked all the wires.
Blub check relay, in the trunk
Originally posted by kylebes1Also where is this thing?
Don't think it could cause the fuse to blow- but anything's possible.......
It's located under the interior panel (carpet) on the left (driver's) side of the trunk- if you have the premium stereo sys- its usually bolted to a bracket with the stereo amp (same location as above).
Bret.Comment
