Idle Rumble/Clutch issues
  • Kristeun
    • 396
    After driving the car for at least half an hour I always notice a rumble coming from the front when idling. It goes away when you depress the clutch, and of course comes back when you release it.
    Also, I can't keep the clutch depressed for more than 6-10 seconds or else it gets stuck about halfway on its way back.
    Anyone have any ideas?
    88 325is
  • 416stroker
    • May 2008
    • 2448
    throw-out bearing...maybe?
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
    • kronus
      • Apr 2008
      • 13032
      Search for the "Getrag Rattle". I have the same problem, and almost did a clutch job before finding out that it was mostly harmless.
      No idea on the clutch depressing.
      cars beep boop
      • Stevie30
        • Apr 2007
        • 1534
        The transmission input shaft bearing is making the noise. Don't worry about it. It will slowly get worse. Mine did the same thing for 40,000 miles before I changed the transmission. The clutch pedal issue is most likely the clutch slave cylinder or master cylinder going bad. It will get worse also. Schedule a replacement before they leave you stranded.
        1991 325ic and 1991 318is
