Transmission selector rod frozen
    The selector rod on my car froze up today in neutral previous to the freeezing I was only able to use R,1,2,5 the problem started last night when 3 and 4 where really hard to get to for some reason, no grinding just didn't catch, any ideas, yes the selector rod is still connected to the selector plate at the knuckle I'm looking for some who knows what might be going on inside, is this the `excuse I was needing to do the engine/tranny swap out of my parts car?
    any help is appreciated.
    Additional question how do you get the control arms off without ripping the ball joint rubber on the outside, used pickle fork and mine ripped, can I fix these or do I have to buy new ones?
    E30 325ix 62k
    Re: Transmission selector rod frozen
    as for your first question, i've never encountered that so i can't help you, start off with check the fluid levels.
    and your second question, use a big ass hammer, it will pop out after some good hits. and if you do rip the boots bmp have urthane covers that will work.
    hth.
    -cam
    Cam .W '91 325is
    Spaz's 1991 Alpine White???? S52 Build Thread...
      Thanks spaz, how the springs treating you?
      There is fluid don't worry, changed it 6months ago, and pulled plug and car was leaning and poured all over my hand love the smell of it don't you.
      E30 325ix 62k
