89 325i
Cruising along at 70 ... boom engine dies.. I try to pop the clutch no luck. Pull over to the shoulder. Crank crank crank... no start.
1st thought was timing belt.. this one has less than 3000 miles on it, but I got that kind of luck.
remove the oil cap. I can see cam moving while cranking.
get the car towed home.
Problem 1. No spark and no fuel (in chamber).
- swapped ECU to known good no luck
- swapped Main Relay with known good. no luck
- swapped Fuel Pump Relay with good one no luck
I can check my check engine lights.. that means the ECU is getting power right?
Also the IACV is humming
I was thinking fuel pump went out, but how do I account for lack of spark?
What are the usual suspects when there is no fuel and no spark?
If it was the CPS wouldnt my plugs be wet?
If my fuel pump or Injector harness was out I would still get spark, right?
I thought this was gonna be easy :(
