Weird locking issues.
  • motorsports_3
    • Mar 2007
    • 1058
    Ever since I put my car back together my locks have been acting funky. I thought while I was welding the area by the trunk that I may have cut a wire in the harness, also I dont think I plugged in the driver side lock, because the key hole does not work.
    I checked the harness and it seems clean.
    If I lock the car with the key from the trunk or the passenger door (my driver locking mechanism does not work) they just unlock instantly. If I have my windows open and lock it from the inside of the drivers door the doors stay locked.
  • itsbrokeagain
    • Jul 2008
    • 199
    might ahve shorted the box out. When you were welding, did you disconnect the battery? Ive popped a few fuses from time to time welding on peoples cars...thank god I didnt harm more than that.
      That sounds like the central locking module thinks that one of the lock/unlock switches is in the unlock position (a bad switch or a wiring fault).
      • motorsports_3
        • Mar 2007
        • 1058
        I didnt disconnect the battery, but I did not blow any fuses. I hope I didnt mess up the central locking system.
        Hopefully. Do you think by not installing the outside lock on the drivers door that could be the issue? When I reinstalled the locking mechanism I didnt install it all the way, because the lock doesnt work. Or atleast I dont think I did.
        How much does a central locking module cost? TIA
        • motorsports_3
          • Mar 2007
          • 1058
          bump
          • StereoInstaller1
            GAS
            • 22679
            I bet the CLS thinks the door is open.
            Closing SOON!
            Thanks for 10 years of fun!
            • motorsports_3
              • Mar 2007
              • 1058
              Holy shit. Luke you are the man. I think that's it. I didn't plug in one of the senors when pukng the car back together.
              • motorsports_3
                • Mar 2007
                • 1058
                Yeah, that was the issue. I just fixed it. It was the CLS thinking a door was open. There is two wires that connect from the big wire harness on the drivers door, behind the speaker. Once I connected the harness, it worked.
                Thanks guys.
